recip saw blades
Discussion in 'Other Trades Talk' started by wild man, Apr 27, 2005.
  1. panlid
    panlid New Member
    bog standard, like i say it must be 80% that have them so that'll be one with recessed bits wouldn't it? so 2 cuts aint never gonna happen.
    roj that was where i started going with my point last night but he went off on one!
    here in n/w every company uses the cill spelling.
    dont know if diff. down south but here it has always been cill.
  2. Rojjie
    Rojjie New Member
    been cill.
    nope, in all my days, man and boy, and all that it's always been a cill down here.
    But Handycapped lives in another world so there it may well be sill
  3. Mr. Handyandy
    Mr. Handyandy Screwfix Select
    I can't believe you two rosie and sid.
    I have quoted you from two different dictionaries on the spelling of sill, and you still have to disagree.
    That makes you ignorant.
    80% of the windows I took out did NOT have recessed sills.
    That's not my fault. That's the way they were built. Is it no wonder that I think that's 'normal' ?
    You just can't take a beating, never lay down. You hate to be told what you should know.
    Not one thing you have picked me up on, have you justified to be incorrect.
    So how come your brains can't overcome the mental block, which says Handyandy must be wrong. It's you that's wrong.
    Disputing a dictionary, that's the tickler, hahahaha.
    ''nkers.
    "But Handycapped lives in another world so there it may well be sill"
    It's in the fkin dictionary
    ''nkers
    I'm still sitting all chuffed hahahaha
    Handyandy - really
  4. panlid
    panlid New Member
    If the window is the original window as fitted when built, sid, you will find that the sill does not extend into the brickwork numbnut.
    remember that one!!!
    not arguing what is normal!
    im arguing that you have clearly stated i am a numbnuts because as you say the cill on an original window fitted when built does not go into brickwork..
    its there at the top of this post.. look at it.
    what about the other 20% of windows you took out?
  5. panlid
    panlid New Member
    andy as i said i am not going to argue all night with you as it is pointless.
    but as you want the last word i will leave it open for you!!
    are you ready???
    get set!!!!!
    GO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  6. Mr. Handyandy
    I remember that one. If you watch a building going up the builders build up the window -with no frame in- so why on earth would they want to put recessed sills in afterwards ?(you will argue that this is not normal)
    recessed sills.
    brickwork..
    Of the other windows I took out, I would guess that 10% had recessed sills, the other 10% would have some other arrangement(sat on tiled sills eg)
    And when I saw these sills I would think Oh fk. The sill is recessed(that means an extra cut)
    I do hope you are satisfied with my explanations(especially where I quoted from the dictionary-and I know it wasn't you)
    Ladidah
    Handyandy - really
  7. Rojjie
    Rojjie New Member
    sills.
    Handycapped - really
    So what you're saying is 2 of the windows you've fitted didnt have horns and the other one did?
  8. Mr. Handyandy
  9. Rojjie
    Rojjie New Member
    to quote your own link,
    (also chiefly Building cill)
  10. BUTTING IN HERE....but thought it was
    WINDOW CILL.....tell me to fornicate off if i'm wrong :)
  11. panlid
    panlid New Member
    LMAO:D
    roj and m3, that spade of his is digging that hole even bigger.
  12. Mr. Handyandy
  13. Pieman
    Pieman New Member
  14. panlid
    panlid New Member
    andy. please tell me where i said the speeling with a 's' was wrong!
    i merely called it cill and not one did i pick you up on your spelling of it.
    i only pointed out that generally window companies use the spelling cill!
    again you go off on one.
    to be honest with you my main gripe was that you called me nimbnut and ignorant for saying windows of a changeable age( and notice the term andy, not new build or built in last 20 years) had the horns set into brickwork which most do.
    now you say 80% of windows you did didnt have this scenario. i simple ask you why you changed so many windows which werent old. which then leads me to think you musnt of changed many windows. i can honestly say that over 80% of the windows i have done do have horns going into brickwork.
    if you say otherwise i guess i will beleive you as you have no reason to lie.
    i can only go of my expierience as indeed you can too.
    good discussion though:D
  15. panlid
    panlid New Member
    sorry forgot to say, its only good because you are giving the HA fan club more ammo.
    carry on dic**pit!!!!
  16. Mr. Handyandy
    again you go off on one.[/i]
    On page 6 in a reply to you sid I said,
    "I do hope you are satisfied with my explanations(especially where I quoted from the dictionary-and I know it wasn't you)
    No-one ever mentioned 'changeable age' before, so why now ?
    too.
    The windows I changed were ex-council house type and yes, they weren't that old. You could probably say that it was those that made up the 80% that were not recessed.
    Discussion ? Snipe more like. Still think I am untarnished. Especially over the sill/cill bit.
    It's in the books that the english language is
    all about. (and I know it wasn't you)
    Fancy Rojie not knowing that cill is spelt S-I-L-L
    Rojie(oh I can't be bothered)
    Handyandy - really
  17. panlid
    panlid New Member
    im assuming by the way that most frames of a replacement age have horns on the head and cill and require cutting.(just a bit of knowledge from EXPIERENCE)
    page 2
    ok you got me!
    i said replacement age not changeable though i didnt think you would be bothered by this small discrepency.
    you know... horns/ recessed!!!!!
    yes i agree about council houses. i did a prior to paint contract changing probably 600 frames on 20 year old houses and they were all actually flush cills, though i am not going to get into an argument about the quantity of council houses to private dwellings.
    the standard 3 bed semi post and pre war are/were recessed horn typed cills.
  18. Gusset
    Gusset New Member
    This argument is getting quite cilly.
    More! More!
  19. Mr. Handyandy
    So if I say Sid is a cilly sunt, it quite right. :):D :^O
    Handyandy - really
  20. panlid
    panlid New Member
    well done andy you never change.
    my last post had some valid points which you choose to ignore again, like every point that doesnt suit your agenda.
