Recommend diy angle grinder
Discussion in 'Screwfix' started by Barra79, Aug 31, 2021.
  1. Barra79
    Barra79 New Member
    Hi,
    I would like to get my own angle grinder. Just now I need to cut a hole in asphalt for a gate post and I also need to cut off the excess length of the galvanised hook to bold that is connected to the fence post. I'm looking for something for general diy work.
    I'm considering this makita model:
    https://www.screwfix.ie/p/makita-ga4530r-720w-4-electric-angle-grinder-240v/5538k
    What disks would you recommend I get with it, one for asphalt and one for metal?
    Thanks,
    Barry
  2. CraigMcK
    CraigMcK Screwfix Select
    I can recommend this one
    https://www.screwfix.ie/p/bosch-gws-7-115-720w-4-electric-angle-grinder-240v/6339j
    I’ve had mine for years, it’s been through a lot and not missed a beat.
    For disks, you would need slitting for the metal and probably diamond for the asphalt, but to be fair I’ve never cut that.
    One thing to remember this is the smaller size, so you won’t get through much more than 40mm before you run out of space.
    Remember eye and ear protection. Potentially full face, if a disk breaks nasty things can happen.
  3. FlyByNight
    FlyByNight Screwfix Select
  4. Offshore
    Offshore Active Member
    Absolutely. I have been in a workshop when a grinder disc broke and it is a violent experience. There is a huge amount of energy released and the result is akin to a small explosion, nasty.
  5. just pumps
    just pumps Screwfix Select
    Never use a grinding disc as a cutting disc, two totally different things!
    Seen one explode because it was being used incorrectly and the muppet removed the guard!
  6. markus11
    markus11 Member
    I've got the a similar Makita to what you are looking at but the version with a paddle switch rather than the slide switch. I find it much easier to use and safer. The grinder has been great for me, I've had it about 3 years (just for diy use).
    The model is: Makita GA4534
    Also depending what else your doing you might want a cut-off grinder guard too (enclosed on 2 sides), they are available for £10ish
  7. mitefix
    mitefix Active Member
