Recticel Insulation Board with electric cable resting on it
Discussion in 'Electricians' Talk' started by Matt_H, Nov 7, 2018.
  1. Matt_H
    Matt_H Member
    Hi, I have just finished insulating under our bedroom floorboards.
    I have used 100mm thick Recticel general purpose insulation board.
    However there are electric cables running through the joists which prevented me from just pushing the insulation boards in.
    So I have had to cut into the Recticel where the cables are.
    In some places the cable may be resting on top of the recticel insulation (not the foil as this has been cut off).
    Is this a fire hazard? The cables aren't actually going THROUGH the recticel, it is resting on top of it and above it is a space underneath the floor boards.
    Thanks
    Matt
  2. chippie244
    chippie244 Well-Known Member
    No it's not.
    Matt_H likes this.
  3. Matt_H
    Matt_H Member
    Phew!
    Am I right in thinking that I shouldn't fill the gaps where the wires drop out of the insulation with expanding foam? I read that this stuff can damage the cables?
    Cheers
    Matt
  4. Coloumb
    Coloumb Well-Known Member
    Pretty much anything solvent based will damage cables, solvent weld adhesive, polystyrene foam, creosote etc. I don't know about expanding foam but I wouldn't want any of it on my cables.
    Matt_H likes this.
