Redfyre no4 back boiler
Discussion in 'Plumbers' Talk' started by Softerz, Nov 10, 2018.
  1. Softerz
    Softerz New Member
    hi guys some advice if I may?
    I have recently bought an ex council bungalow, the living room has an open fire with what I believe to be be a Redfyre no4 back boiler inset. I have no water tank nor any obvious pipe work coming from the fireplace... on the front of the boiler are several random drill holes... this leads me to believe the boiler has been drained and decommissioned and the holes are to allow the pressure to escape? Is this safe to use as a fireplace? any thoughts would be much appreciated?
  2. kiaora
    kiaora Well-Known Member
    Hi
    Yes it’s safe to use, it was common practice to drill holes in the back boiler, to avoid any risk of trapped water boiling and causing problems.
    Regards
    Peter
  3. Softerz
    Softerz New Member
    Thank you Peter
