Reducing the height of curved plastic shower plinth
Discussion in 'Plumbers' Talk' started by Mikeee67, Oct 13, 2021.
  1. Mikeee67
    Mikeee67 New Member
    Having the bathroom flooring replaced and will need to cut down the height of the shower trays plastic plinth, was thinking of taking some off the bottom using a multi tool with fine toothed blade. Presently held in place with magnetic tape and sealed top and bottom with silicone. Any thoughts would be appreciated
  2. dcox
    dcox Screwfix Select
    I’d use a diamond disk on an angle grinder to cut the panel, then finish the bottom off with a strip of upvc window edging.
    Mikeee67 likes this.
  3. WillyEckerslike
    Are you leaving it in situ? If so I'd be inclined to go with your plan. If not, I'd follow the advice given by @dcox but you might not need the window trim. Depends how good you are at applying silicone I suppose.
  4. Mikeee67
    Mikeee67 New Member
    Thanks for your replies. Intended to cut in situ and then remove for new floor covering to be fitted and then refit plinth without silicone for easy access
