Register plates under mantelpiece
Discussion in 'Builders' Talk' started by C00kie123, Oct 15, 2021.
Tags:
  1. C00kie123
    C00kie123 New Member
    Hi everyone
    The register place above the log burner is deeper than the fireplace and is screwed into the underside of the mantelpiece.
    I want to remove the mantelpiece and have one of those floating oak beams instead.
    Do I
    A) have the oak beam at the same level as the mantelpiece and screw the register plate into the oak beam?
    B) get a smaller register plate which finishes flush with the wall?
    C) something elseā€¦
  2. Adamfya
    Adamfya Screwfix Select
    post a picture
  3. C00kie123
