Rejecting a new patio.
Discussion in 'Landscaping and Outdoors' started by Daniel P, Jun 19, 2019.
Withhold payment/reject work?
  1. Yes, reject.
  2. No, it's fine.
Results are only viewable after voting.
  1. Daniel P
    Daniel P Member
    Just had a patio "half" installed by some contractors. Due to issues with their measurements, we have to wait for more materials to arrive. The patio caught my eye earlier as I thought it looked a bit out of level, and so have just gone to check it.
    I have pictures attached, and am considering witholding payment for this part of the work unless it is rectified. Just wanted to get other people's opinions before I do anything drastic.
    Just for reference, the garden slopes from left to right at about a rate of 1-2mm per meter, so basically level, and slopes away from the house at about 5-10mm per meter.
    The overall drop on the laid patio seems acceptable, however is not uniform and has resulted in dips and raised portions which concerns me with regards to flooding.
    What do you guys think?
  2. Diyloser
    Diyloser Active Member
    They were quite good over the whole length according to the bubble, just forgot the bit in the middle :).
    Is it acceptable, well i wouldn't except it on one of my jobs.
    The nature of the slabs will cause some dipping and raised areas but this is across numerous slabs so should be better.
    The fall away from the house is too shallow if as you said above, it should be nearer 50mm in 3 metres to get a good flow away.
  3. ramseyman
    ramseyman Active Member
    Sadly you will definitely end up with puddles/ponding, depends if you're prepared to put up with it, I wouldn't be. Presumably they still have grouting to do, if you let them do that a hose over the area once that's done will immediately show the issues. Best to get them relaid to a constant fall now.
  4. Not Too Sure
    Not Too Sure Member
    You’ll end up with a big puddle in the middle - just have a chat with them about your concerns.
  5. Daniel P
    Daniel P Member
    Thanks guys. They're due back tomorrow, so I'll explain my concerns. Hopefully they'll take it on the chin and redo them.
  6. gas monkey
    gas monkey Well-Known Member
    redo or regret
  7. blarblarblarblar
    blarblarblarblar Active Member
    Errrr, that is poor, there is nothing right about that.
  8. masterdiy
    masterdiy Active Member
    Is that Your level & decking board?
    If so, show the guys in the morning & ask if they want to borrow it.
    Ps. That is terrible. :eek:
  9. Daniel P
    Daniel P Member
    I left it out for them to use
  10. Astramax
    Astramax Well-Known Member
    If you are loaning these fella's your tools surely that should have told you something!
    masterdiy likes this.
  11. koolpc
    koolpc Well-Known Member
    Very poor work indeed
  12. Daniel P
    Daniel P Member
    I was kidding about lending my tools :D
  13. DIYDave.
    DIYDave. Well-Known Member
    Plenty of rain across most parts of the country, should be plenty of pooling water ready for the guys to see in the morning
    How are they gonna argue with this watery evidence
    Plus leave the level / timber across the worst dips with the complete edition of Encyclopaedia Brittanica in the gap as a visual reference
    Good luck with this issue
  14. Daniel P
    Daniel P Member
    Just a little update to this issue.
    A large portion of the patio ended up being redone, and the builders blamed it on the slabs 'sinking' overnight, which I am fully aware is BS.
    The patio is still not perfect, but it is acceptable and doesn't pool, so we paid and left it at that.
    Now however, my neighbour decided she wants to have her fence done, and has had it pulled down. Her builder will now not put a new fence up, as he says the work on my side is unsafe and likely to collapse. He has said that my patio and decking will need to be ripped up and all redone safely.
    There's a picture of under my decking, and her side of the fence attached. You can see the subbase just seeping out under the fence. Does this require a retaining wall? I'd like to contact my builder armed with actual knowledge instead of guesswork.
    Beginning to wish I'd done the lot myself.
  15. Daniel P
    Daniel P Member
    I just noticed from my own pictures that they've even joined the fence kickboards in-between two posts, instead of at the post. Surely this is also wrong?
  16. Heat
    Heat Well-Known Member
    There is a large screw sticking through the timber towards your neighbours side (in last photo) and it could be dangerous, especially for a child or anyone to fall against or touch.
    I also see kids footballs etc, so obviously risky.
    The modern screws are self cutting and are lethal sharp.
    Could be more screws.
    Best to get them cut flush now
    Cowboy job
    KIAB likes this.
  17. KIAB
    KIAB Well-Known Member
    Complete cowboy job.
  18. Ton Tigs
    Ton Tigs New Member
    Very poor workmanship!
  19. sospan
    sospan Well-Known Member
    There shouldn't necessarily be sub base under a decking supported by posts, what you have there is some rubble and debris from some other work.
    The concern is that the fence that is there may be too "heavy" for the length of posts. It would be quite an easy solution to fit another post in the ground next to the current ones and fix them together they can be either concrete or timber. Your neighbour can then fix her fence to these but If there is a fence there already why put a second up ?
    In terms of the screws sticking out, just tap them with a hammer so they bend over, most will just snap off.
    The decking hasn't been put together in the best way, probably won't last as long as it should but doesn't warrant ripping up and starting again.
    If you have some more pictures it would help to see if there are any more issues
  20. blarblarblarblar
    Does it require a retaining wall? I’d say so, if it was going to be done properly, but I’d say that you have been properly done.
    Good luck getting them back.
