Remove shaver socket for a PIR
Discussion in 'Electricians' Talk' started by uncle sam, Nov 19, 2021.
  1. uncle sam
    uncle sam Member
    I have a shaver socket that never gets used, the cable then goes into a over sink light fitting, so i was thinking that id get much more use if i could take out the shaver socket and replace with a PIR, main reason is for when kids go toilet in the night as they cannot reach that light and i dont want main light on as it will turn on extractor (ie i dont fancy turning off the isolator ever night)
    Is there a PIR that would fit on a 2 gang box?
  2. Lectrician
    Lectrician Screwfix Select
    No. And not one that wouldn’t require a neutral either, which you would loose when introducing a switch return.
    uncle sam likes this.
  3. Teki
    Teki Screwfix Select
  4. uncle sam
    uncle sam Member
