I want to remove a double glazed uPVC window from between my kitchen and conservatory. I can see there is a metal lintel above and it looks like the flat metal type 150mm over each side. The window measures 117x105cm. The property was built around 1990. I wanted to plaster it all in then put a window board and wood shutters in its place. Any advice much appreciated.
Picture paints a thousand words. If all is described take frame out, cavity closures, plasterboard, skim it over job done.
