Removes old tiles please help
Discussion in 'Tilers' Talk' started by Ashbou10, May 12, 2020.
  1. Ashbou10
    Ashbou10 Member
    Hello is there a solution to this nightmare i took the old tiles off the wall is a complete wreck and found something to be bonded to the wall which is sticking out, also had to fill a massive hole, whats the solution here guys?
  2. DIYDave.
    DIYDave. Screwfix Select
    The ‘solution’ partially depends on what your planning as a final wall finish ?
    More details required
  3. Ashbou10
    Ashbou10 Member
    The plan was to tile the wall
  4. DIYDave.
    Before tiling, the wall needs stripping of all loose material, plaster, paint, cement render (?) and ideally, deep holes filled then the wall/s skimmed over
    You want a nice, flat surface to tile on to get best results, especially if your diy tiling this
    The larger the tile you use, also need s the wall to be super flat
    Looks worse than it is, all standard stuff and not a nightmare really
    Often when removing tiles, you loose a lot more plaster and expose the brick work
    Just needs several stages of prep before tiling. Are you planning on doing all the work yourself or getting in any trades ?
  5. Ashbou10
    Ashbou10 Member
    Thanyou for the reply well the plan was to tile myself as ive already done have the bathroom but this has just stopped me
