I'm just in the process of removing a radiator from my microbore system. The pipes are set into the concrete floor. I want to remove the pipes from the manifold rather than put stop ends on. What's the easiest way to work out which pipes at the manifold feed that radiator please?
keep the radiator in question turned off. Turn on heating and make sure the other radiators are on. All the microbore pipes should now heat apart from 1 on each manifold. This should be the 2 pipes to radiator. The further away from the manifold the better for checking the pipes.
