Removing 10mm rad stop end
Discussion in 'Plumbers' Talk' started by tore81, Jul 31, 2020.
  1. tore81
    tore81 Screwfix Select
    Hi all I need to reroute 10mm barrier pipe and remove the stop end push fut.
    need to remove live as no drain offs etc. I’m guessing there will be a lot of pressure.
    I will have a bucket handy but is there any tips as to ease the pressure etc. I’m lucky as I have a plastic tail close to back door but just want to check.
  2. METRO MARK
    METRO MARK Active Member
    No drain Offs....
    Is it a combi
    Do you have a filling loop?
  3. tore81
    Yes it is a combo, I have drained off before but not sure what to expect with removing push fit end
    I know how to repressure etc. Just not done it without drain off.
  4. METRO MARK
    Ok
    Is the Radiator Physically Lower in respective to the boiler or higher ?.
    The filling loop you could use to do the reverse function, and Empty the system down to the boiler level...
  5. terrymac
    terrymac Screwfix Select
    You should reduce the pressure in the system ,before trying to remove the stop end. Whatever pressure is showing on your boilers gauge ,is what you have in the system.
    Drain some water out to release the pressure.
  6. tore81
    Great thanks both so have a bleed off valve upstairs in rad so just let some pressure out of that.
    pipes are dropping down! Rad not fitted yet
  7. tore81
    It’s lower boiler is in airing cupboard upstairs
  8. METRO MARK
    Gravity will be against you :rolleyes:
    As terry says you could do with releasing some pressure from somewhere!
    A bucket under the boiler.....get ready
    or Lift the PRV,,, release some water outside till pressure drops to 0
    tore81 likes this.
  9. tore81
    Under the boiler? There is no bleed of rads so I’m thinking of releasing pressure from bleed valve
  10. METRO MARK
    Whatever floats ya boat, and it will....
    Use a upstairs rad to bleed off pressure off
    what Make & model of boiler is it ?
  11. tore81
    It’s a Worcester boiler fairly new
  12. tore81
    It will .... ??
  13. METRO MARK
    The gravity will let the water come on down..
    You can reduce this by
    1 Reduce the pressure
    2 close off all valves on radiators.. Up n Down
    3 switch OFF boiler, and close flow & return valves under boiler
    4 get ya bucket ready to remove stop end..
    and once the flow has moderated a bit and is glugging.........get it into the rad.
    Why these plastic pipe fitters don't install drain off points i never know...
  14. tore81
    I know annoyed I’m having to do this! Especially as they asked to re route.
    I’m not putting it into rad I just have to plasterboard and skim before rad goes on. Stop ends will go back on
  15. METRO MARK
    Ah OK
    Closing off all the valves on as much as you can will cause a vacuum hopefully
    So the only way water can come out, is if it's replaced by Air... hence glugging noise...
    Air will try and get sucked into the pipe you remove the Stop End on....This is going to be the point you start to relocate the Pipe..
    Work quickly, and wisely don't panic;)
    Have some bath towels ready
    And Go for it....
    Have a Beer ready on completion
    Punch the pratt of a heating engineer....(LEGO PIPE FITTER):mad:
    And don't let them use the Loo
    tell em to Go to McD for a free McS***t
    They should really just chuck the stuff straight down the bog, cut the middle man out.
    OK rant over
    tore81 and WillyEckerslike like this.
