Removing Bannister
Discussion in 'Carpenters' Talk' started by Philipo51617, Mar 29, 2019.
  1. Philipo51617
    Philipo51617 New Member
    Screenshot_20190329-181852_Gallery.jpg I'm replacing handrail, bannister, spindles but dont know how to get this section removed.
    Any help welcome.
    Cheers
  2. Jord86
    Jord86 Screwfix Select
    You will have to cut through the tenons, run a sharp handsaw down the newel posts into the handrail from above, it will then tap up with a hammer and you'll be able to cut through and remove the infill panel.
  3. Severntrent
    Severntrent Screwfix Select
    Why not cut out the middle half of the hand rail and then try and wiggle the remaining quarters out of the newels
  4. Jitender
    Jitender Screwfix Select
    Whats the gap measurement between the newel post?
    Although the stair is older than some of the regs, the gap has to be 4"/100mm or less, so may only get a spindle in here and may look a bit odd.
  5. Philipo51617
    Perfect thanks
  6. Philipo51617
    Yeah only 1 spindle will go in, neighbour has done the same and looks better than the piece of board that was there in line.
    Cheers for reply.
  7. Jord86
    Tidy. What you planning to replace it with?
  8. chippie244
    chippie244 Super Member
    Expanding foam:)
    KIAB likes this.
  9. Philipo51617
    Not decided at the mo, leaning towards the chamfered spindles or the colonial / Georgian.
  10. Jord86
    If your opting for chamfered, come down 4" from the top and 8-10" from the bottom of the newel posts and run a router in between on the four sides with a chamfer bit, neatens them up and gives the balustrade a new lease of life.
  11. Philipo51617
    Cheers for the tips, much appreciated
