Removing floor tiles for solid wood flooring
Discussion in 'Builders' Talk' started by nrg, Feb 12, 2018.
  1. nrg
    nrg Member
    Hi
    I'm current removing about 50m2 of floor tiles in preparation for solid wood flooring.
    As I'm taking each tile up the grout is left behind and therefore leaves about a 2mm or so uneven surface. Will I get away with just putting a decent underlay down such as Sonic Gold and then the solid wood flooring (15mm depth) on top, or will I have to chip away at this grout :/ I thought about using a self levelling compound but that will be really tricky as its all open plan and I can't clear the area of furniture.
    Thanks in advance for your help
  2. KIAB
    KIAB Well-Known Member
