M
Mr. Handyandy
Guest
Yah, but the tube would have to be quite hefty(if the nuts are as tight as the others).
If you like a lot of effort, have a go at this(when you've stopped laughing).
Find a hefty nut, as big as possible that fits the recess and you can get a real good fitting socket onto. Main spec is that it has a 10mm hole to fit over the projecting bit in the middle of your stud(tighter the better, but hand-moveable).
You will also need a couple of hardened masonry nails(choose you thickness, but I sugest 3mm).
Using the holes you have in your stud as a guide, drill them deeper(you will need to drill them 5mm deep), then drill corresponding holes in you nut(nice wide flange you should have to work with) again, 5mm deep.
Using whatever method available to you(anglegrinder, diamond cutter/hacksaw whatever) cut the number of pins you need out of you hardened nails, 10mm.
See where it's going ?
Tap the pins into the nut(gently), they should be a hammer-tight fit. Insert the nut onto the projection in your stud(now you will need to turn and locate the pins into the holes in your stud)
Hope you cleaned up the ends of your cut pins
Once you are sure they are located, tap the whole lot fully in with your hammer(and drift if necessary).
Stick your hefty socket and lever(lever, not ratchet).
Put as much pressure on your lever as you feel safe enough not to bust your contraption.
Once you have pressure on(and if the stud hasn't budged),
BELT the lever NOT to turn it, but on the end of the turning axle(as if you were going to bash the stud right through to the other side of the wheel) whilst keeping the same pressure on your levering.
The nut is undone.
(If it's not, I can't help!!!!)
Mr. HandyAndy - really
The nut is undone.
