Ive just removed some stick on lead from my conservatory double glazed units, it came off fine but how do i get the remaining double sided tape adhesive off? What spirits is best to use? I tried turps and petrol but to no avail, also using a window scaper any suggestions ? thanks
Thousands of uses. https://www.google.co.uk/url?sa=t&r...000_uses.pdf&usg=AOvVaw11VAz7mLNZ8aCLTFB2sG6W
Working on a renter recently and used white spirit, which worked quite well. Still a few stubborn bits so will now try wd40...cheers Astra
