Rendering Substrate Advice - Boarding over uPVC
Discussion in 'Builders' Talk' started by greddymop, Mar 8, 2020.
  1. greddymop
    greddymop New Member
    A little bit of advice please, regarding a suitable rendering substrate (see the Eurocell uPVC cladding in the photo below).
    Will be rendering over the pebble-dash (after removing and filling the areas that have blown) - though also want to smooth render the Eurocell PVC area, so the rendered finish is consistent.
    The PVC is set-back about 5cm from the pebble dash, hence the requirement to build-up the area in advance.
    Was thinking battens and boarding over the top of the UPVC, and then a mesh / primer / etc. build-up on top. However, not sure what boarding to use (hardwood ply, with a weatherproof seal on the edges?).
    So throwing it out there, what would anyone suggest? Doesn't need to look pretty - but does need to be functional.
  2. Neil1987
    Neil1987 Member
    What's behind the pvc? Couldn't windows have been bigger? Where is he sill on the windows?
  3. greddymop
    That probably shows things better - the windows are that height, to match the bay-window to the right.
    The new windows, door and blocks replace an old sliding door that was originally installed (before and after).
    To be fair, I am tempted to pull the cladding off - but hoping a simpler solution can be found to build something up over the top to render onto.
  4. Neil1987
    Neil1987 Member
    Bay windows look taller than new in photo I would probably frame it out then hardy backer it but your windows have no sills so water that runs down windows will just seep under window and inside
