Repair damp wall? Total novice
Discussion in 'Screwfix' started by ennewd, Jun 29, 2020.
  1. ennewd
    ennewd New Member
    Hi all
    Recently moved into a new property (1960) semi detached house with no issues until we started painting and noticed a small area of ?damp (I’m a total diy novice) which had peeling/ flakey paint so we covered the area with damp seal which lasted about 3 weeks until it bubbled. What should we do ? I’ve took the damp seal off and sanded the area.
  2. Astramax
    Astramax Screwfix Select
    Can you also post a picture of the outside area.
  3. ennewd
    ennewd New Member
    Hi see link below
    https://ibb.co/tm4X0st
  4. Astramax
    From the photo it is not very clear to see any damp, is there a musty smell present, the outside porch wall may be a clue, have you checked the condition of the porch flat roof etc?
  5. ennewd
    ennewd New Member
    No musty smell but before I put the damp seal on the area was flakey and efflorescence coming through. Below links are after I put it on and after 3 weeks scrapped bubbles off
    https://ibb.co/PFG1fN1
    https://ibb.co/xMsZHFn
    https://ibb.co/K7pVm2n
    https://ibb.co/jZWf6jT
  6. ennewd
    ennewd New Member
    Here’s a photo the day we moved in lol hidden behind a curtain
    https://ibb.co/zN8qsDf
    n
  7. ennewd
    ennewd New Member
  8. Joe the Plumber
    Is the pillar supporting the front porch roof actually tied in to the main wall (ie do its bricks go into the wall) or is it just
    resting against the wall?
    If it's not tied in, I'd suspect rain water is being trapped between the pillar and the wall and coming through into the hallway.
    Re-pointing should sort it out, unless the leak is from the porch roof.
