I'm decorating, and the old SL Compact (Optima clone ?) control panel is on a wall that I need to paint and looking rather old and yellowed, I think it is 23 years old and original builder fit when the house was new. It is still working, and I've had the front off the panel and replaced the back up battery - so I think I must have had (or guessed a default) the engineer code when I did that ?
I now want to either remove the panel to decorate, or possibly update it
I'll need to replace / remove to decorate PIRs in a number of rooms, and I'm also replacing front and back doors which have yellowed and ugly magnetic (I assume) contacts surface mounted on them
I'm not inclined to go wireless if I can just replace things and stick with the original wiring - but maybe I should be enhancing at the same time as replacing
main drivers behind thinking about this are the need to do something when the main entry doors and frames are replaced, and the aesthetics of yellowed old PIRs and the panel (which is pretty obtrusive on downstairs loo wall)
DIY skills are not too bad - I've done a fair bit of wiring, electric shower back in the day, new sockets, garage consumer units, glands on armour cable etc - so I'm reasonably equipped to replace stuff myself
Any clues on where to start gratefully appreciated....
Can I perhaps just buy new PIRs, main panel and keypad for by the entry door and do a straight swap using original wires ?
4 bed detached, don't set in zones, just use it very simply when the place is left empty. Have pretty normal (currently BT) router and reasonable wifi - FTTP avaialable - but no ring doorbell or camera to add in (at the mo at least) to the equation.
Is there an easy straight swap I should be heading for ?
Thanks in anticiaption
