Replacement metal manhole covers?
Discussion in 'Plumbers' Talk' started by rorysf, Oct 15, 2021.
  1. rorysf
    rorysf New Member
  2. kiaora
    kiaora Screwfix Select
    Hi
    One thing here, is, you don’t have to get the same size or shape,
    Most drain covers metal or plastic, come with a frame, so, if you remove the lids, and the bit of frame their in, and then install a new, slightly bigger cover and frame !
    good luck
    Peter
    rorysf likes this.
  3. robertpstubbs
    robertpstubbs Screwfix Select
    Check the height (thickness) of the new one is the same.
    Also changing the frame means redoing the surrounding concrete, but it looks like that needs doing anyway.
    rorysf likes this.
  4. rorysf
    rorysf New Member
    Thanks all
