What's the average cost to replace a single worktop (I already have this) and put 3 cupboard doors on in a kitchen (which I also have)?
Type of worktop? Size? Does it have cutouts for hob or sink? Does it have to join another worktop? Are the walls tiled? Is there reasonable access to the kitchen and somewhere large enough and flat enough to set up some benches to cut the worktop? How close can the fitter park his van? These are just a few of the questions for which the answers would determine the cost.
With such a rich mine of information within the opening post, how could anyone give a reasonably accurate answer?
I had no idea that the Welsh had dropped prices that low................covid must be worse in Wales than i thought
Thank you for this, I apologise for the lack of info in the initial post I am just clueless and didn't know what to ask, so thank you for posing these questions to me. It is a laminate worktop, about 225cm long and 60cm wide. There is a cutout for the sink and there is a metal strip where it would join to another worktop. There are no walls involved and there is reasonable access. The fitter can park right outside as there is free on street parking. Thanks OkOak
If everything is straight forward, 1/2 a day? Rate depends on where you live, that would be around £125 in my area. If there a materials needed like clamps or router bit, they could charge extra for those.
