Hey all,
Having had a read around I just wanted to check the following would work.
I intend to get a Nest 3rd Gen and replace my old hallway thermostat with it. The old one only used a two wire system and is used to control my British Gas Programmer which is located near the boiler.
I understand that you can install the Heat Link system to replace the programmer, but from what I've read you can also use the Nest to simply send the signal to the original programmer using the 2 wires already present, as shown here:
I just want to be able to switch heating on and off and set timers, so pretty simple setup.
All the videos seem to be US based so just wondered if there are any issues with doing this in the UK?
Cheers
Chris
Cheers
Chris
