Replacing chipboard flooring.
Discussion in 'Carpenters' Talk' started by lworth93, Jan 24, 2023 at 8:55 PM.
  1. lworth93
    lworth93 New Member
    Hi
    Could anyone tell me or send me a link to the best plywood to replace the old sagging chipboard flooring is please? Know it needs to be a minimum of 15mm for the width of our joists so was going for 18mm ply, but merchants and other ply sales places seem to be abit vague on what can and can't be used for flooring.
    Thanks
    Liam.
  2. CGN
    CGN Screwfix Select
    Why do you want to use ply?
  3. Mark Griffiths
    Mark Griffiths Active Member
    18mm chipboard is a good idea. Any builders merchants, focus, B&Q are all stockists.
  4. lworth93
    lworth93 New Member
    Because it's supposed to be stronger than chipboard.
  5. rogerk101
    rogerk101 Screwfix Select
    22mm T&G chipboard made specifically for sub flooring, glued and screwed into the joists and glued to eachother. It will be rock solid, without any squeaks or creaks.
    Kitfit and CGN like this.
  6. CGN
    CGN Screwfix Select
    see above
