Replacing Drayton LP111 with Center BDR91 - HELP!
Discussion in 'Engineers' Talk' started by Pete90, Jan 8, 2022.
  1. Pete90
    Pete90 New Member
    I'm looking to replace my fixed boiler control unit with a wireless thermostat (so that i don't manually have to switch boiler on & off). Need some help in understanding how to rewire my existing control unit (Drayton LP111) with the wireless thermostat (Center BDR91). I've added all the images i have of the wiring. Hopefully i can get some help on this
    TIA
  2. Teki
    Teki Screwfix Select
    Which boiler do you have?
  3. Pete90
    Pete90 New Member
    Vokera Linea Plus
  4. Teki
    LP111 - BDR91
    Brown - L
    Blue - N
    Connect jumper wire from second L terminal to A
    If there is another wire in terminal 1 - also connect it to A
    Wire in terminal 3 - B
    If you have an existing wired thermostat, the wires will have to be linked.
