Replacing electric meter seal
Discussion in 'Electricians' Talk' started by StupidSteve, Sep 4, 2013.
  1. StupidSteve
    StupidSteve New Member
    SOMEONE cut the little seal to the electric meter outside after it was disconnected.  possibly also removed the 2 plastic covers over the meter connection prongs.  only 2 out of the 4 were covered and both are lost!   how can i fix this before the meter guy comes and i pay to have electric restored?   can i buy this stuff at a local electric supply or not? trying to minimize the the fines and legal issues,   it ran power for 2 days.   btw ya i know im stupid,  im desperate and i have a child.  all help is days/weeks away
  2. Sean_ork
    Sean_ork Screwfix Select
    who disconnected it ?
    if you've done nothing stupid, or illegal you have nothing to worry about - whoever comes to repair/replace/resupply will reseal
  3. J.P.
    J.P. New Member
  4. StupidSteve
    thanks!   1 sleeve is all that was found from the 2 the power company covered the male prongs with that connect the meter.  1 was put back but electric came back on in minutes.  just pull meter out to unplug it or can i buy theese small sleeves?   yikes.   i just want the meter off,  having a cut tag is bad enough  :(
  5. Sean_ork
    thanks for clarifying that
  6. StupidSteve
    can these items be bought at a local electric supply place ?   meter safety lock, special tool for safety lock and the little sleeves that cover the male side prongs where meter plugs in?
  7. stateit
    stateit Screwfix Select
    That's a bit of a hole you've dug for yourself there...
  8. sinewave
    sinewave Screwfix Select
    Rather an apt user name there OP!
