Replacing IMIT Thermostat
Discussion in 'Electricians' Talk' started by kidfromkibbly, Jan 16, 2020.
  1. kidfromkibbly
    kidfromkibbly New Member
    Hi folks,
    Moved into an older property recently with a gas central heating system. We'll be upgrading at some point in the next 12 months, but something that is bugging me is the room thermostat being used.
    It's an old IMIT T50II:
    [​IMG]
    and it's currently wired as such:
    [​IMG]
    It's mounted in the hallway, near a draughty kitchen door. I'd like to put in a newer model thermostat and extend the wiring to site it in the living room for more accurate heating control.
    I'm looking at getting the Drayton Digistat+ as it's also a 2 wire installation, so seems like a good replacement. I've noticed though it mentions in the Q&A that "The Digistat+ is compatible with all boilers but please note the switch rating is 2(1)A."
    On the IMIT it's marked as being 16A(2,5)
    I'd appreciate any help in explaining if this means the Drayton is not compatible with the circuit, or what steps I need to take to correctly wire in the Drayton. Thanks!
    ps. boiler is also wired to a Flash programmer unit seen here:
    [​IMG]
  2. Philip Hyde
    Philip Hyde Active Member
    Its difficult to say without knowing what its wired into on the boiler and Type of boiler make and model
  3. kidfromkibbly
    No problem, it's the Baxi Bermuda GF3 Super.
    [​IMG]
    I can try get a shot of the wiring on the unit this evening.
  4. kidfromkibbly
    Just clicked that that is just the front fire to the boiler :rolleyes:
    Will look at boiler for model number later.
