Replacing old Ceiling Spots
Discussion in 'Electricians' Talk' started by Kodak Man, Feb 1, 2004.
  1. Kodak Man
    Kodak Man New Member
    Do they make a conversion unit to help replace the older spot lights in Ceilings with the new low voltage units. My questions relates to the size of hole cut in the older spot lights that is much larger than the newer units etc.. I wanted to check before I replaced the ceiling completely, my hope would be that they do a new low voltage bulb in a housing that requires the older spot light larger hole?... Any thoughts please. thanks
  2. finjon
    finjon New Member
    I've put new lv's into old spots. Look quite good too. Just got lucky with the sizes. You could do a bit of searching for a fitting that will fit the old diameter.
  3. ban-all-sheds
    ban-all-sheds New Member
