Replacing old concrete floor in bathroom
Discussion in 'Builders' Talk' started by Nigel Wagstaff, Sep 11, 2019.
  1. Nigel Wagstaff
    Nigel Wagstaff New Member
    Hi there everyone.
    I am renovating a bungalow at the moment and we have got to the bathroom! The floor is concrete and over 2 layers. The first (top) layer was pretty messed up and we decided to take it out. The concrete is 50mm to 65mm deep in a room that is just short of 3 meters long by 1.5 meters wide.
    Below the concrete was a clear polythene membrane on top of another slab of concrete that was floated off with the footings. This lower slab is much harder and a good 5" deep. Closer to the window I have cut in a gully to run water through the bathroom into other rooms beyond and to gain access to the drains for a low level shower we have planned.
    While I know the easiest thing to do it to get another membrane and fill it with cement again, I want to consider the possibility of insulating the floor and capping with suitable plywood or possibly "No More Ply Tongue & Groove Board 22mm"
    One thought is to lay a membrane, add a timber frame and slide 25 - 30mm of insulation in before adding the top sheet. My only dilemma is how to secure the timber frame to stop it from sliding and lifting in such a thin space!
    I would welcome comments on how to do this or something similar.
    A few pictures . . . .
    Thanks in advance
