I need to connect a new PIR, connected to two lights and one switch. Any idea on where the live, switched live, and neutral from the PIR should go into the existing wiring on the external wall plate? Thanks!
You will need to trace where each cable goes. If you have a multimeter or can borrow one, that will help.
