Repointing old house
Discussion in 'Builders' Talk' started by Mancone, Oct 8, 2020.
  1. Mancone
    Mancone Member
    My house was built in 1904 and I need the table wall repointed.
    Guy is going to use 3 parts sharp sand and one part NHL.
    Soooo are you going to tell me ive messed up already? Anything to watch out for?
  2. Joe the Plumber
    As long as he's not using any cement, that sounds okay I think (I am a plumber, not a builder though!)
    Or you could just buy ready to use (just add water) lime mortar from here:
    https://www.lime-mortars.co.uk/
    Mancone likes this.
  3. Bob Rathbone
    Bob Rathbone Screwfix Select
    If you use OPC with old bricks, the bricks will spall and shatter in time. Lime mortar is a sacrificial device, it absorbs the moisture from the brick and spalls during freezing, leaving the brick largely intact.
    Mancone and Joe the Plumber like this.
  4. Mancone
    Mancone Member
    What’s OPC
  5. Nanook
    Nanook Active Member
    Ordinary Portland Cement
    Mancone likes this.
  6. Severntrent
    Severntrent Screwfix Select
    Ordinary Portland Cement,
    Mancone likes this.
  7. Severntrent
    Snap
    Mancone likes this.
  8. Mancone
    Mancone Member
    Oh yes the stuff I have at home.
    yes I will ask to see what they are mixing before. I’m sure they won’t quote and use cement, hopefully.
  9. Nanook
    If they won’t quote and are likely to use cement, sack them off and find someone else who will quote and knows about lime mortar.
    Joe the Plumber and Mancone like this.
  10. Mancone
    Mancone Member
    They’ve quoted and coming Monday. I meant in the quote they don’t say normal cement. I’ve just had a lot of bad luck recently.
  11. Nanook
    Yeah I saw your kitchen nightmare. Join the club, I guess that’s why you’re here like me and trying to get the right advice and knowledge to avoid anymore DIY SOS!
    Mancone likes this.
  12. Mancone
    Mancone Member
    Agh.
    So they are on site. There is an open bag of lime that doesn’t look like a lot has been used. Three empty bags of sharp sand.... is there a problem? I’ve checked the bin as well.
  13. Nanook
    Not necessarily, but it would be best to ask them straight out what mix they are using and show interest in it and their workmanship.
  14. Mancone
    Mancone Member
    I have asked several times. 3:1. They said they are using shovel sizes, no like one bag lime to three bags sand. Also not by weight as well. Doesn’t sound right...
  15. Mancone
    Mancone Member
    They’ve finished and did an ok job.
    However...... the bricks look dirty. Should they have washed them?
  16. Abrickie
    Abrickie Super Member
    After raking out, prior to re pointing
    Mancone likes this.
  17. Mancone
    Mancone Member
  18. Mancone
    Mancone Member
    I can’t remember them doing it.... there was no water
  19. stuart44
    stuart44 Active Member
    Jord86 likes this.
  20. jonathanc
    jonathanc Screwfix Select
    nah it’s right. Mixing by counting shovels is fine
    Mancone likes this.
