Repointing old house
Discussion in 'Builders' Talk' started by Mancone, Oct 8, 2020.
  1. Abrickie
    Abrickie Super Member
    Bucket handle with lime mortar ?!!:rolleyes:
    What are they teaching kids these days :mad:
    Mancone likes this.
  2. Mancone
    Mancone Member
    Agh.... what’s the worst that will happen :(
  3. Astramax
    Astramax Screwfix Select
    Before surely. :eek:
  4. Mancone
    Mancone Member
    Agh, no after. That are doesn’t look the best but the rest of the wall does. The bricks are quite uneven.
    I’m starting to worry why the mortar wasn’t put all the way to the end of the bricks?
  5. stuart44
    stuart44 Active Member
    Do you want a flush joint? They look recessed in places.
    Before starting a repointing job I would always check the style of joints required.
    Lime pointing is often finished flush with the churn brush.
    Mancone likes this.
  6. Mancone
    Mancone Member
    I didn’t know this.
  7. Abrickie
    Neither did the kids who did it, the pointing looks as if it’s had several decades of weather on it already :rolleyes:
    Mancone likes this.
  8. stuart44
    Joints can be recessed, but on a solid wall like yours a flush or weather struck is preferred, as the recess allows a ledge for moisture to sit.
    Mancone likes this.
  9. Abrickie
    Big fan of recessed joints for feature work, but with lime mortar, sort of defeats the purpose of repointing
    Mancone and stuart44 like this.
  10. Astramax
    Though it was the street set from Poldark! :oops:...;)
    Mancone and Abrickie like this.
  11. stuart44
    Yes, brickwork can look really good with them. You do need the right bricks(and bricklayers) for them.
    The ones in the photo don't look right, as some look full, others recessed a bit, ones been jointed. Think he should have gone for a flush joint. Trouble with the churn brush, when people wack the brickwork too early it can put lime stains over the brickwork. The brush should always be clean and if it isn't leave the joints for longer.
    I'm doing a lime pointing job at the moment but as it's Chert stone it does not matter too much if the pointing is still a bit wet.
    Mancone likes this.
  12. Mancone
    Mancone Member
    Agh. Annoying
  13. Mancone
    Mancone Member
    Maybe he will come back, I don’t know. Agh.
  14. Mancone
    Mancone Member
    Why would he do it the way he has. The wall looks dirty all over. I’m guessing rain won’t help it?
  15. Mancone
    Mancone Member
    Another bad job for me :( I thought it was ok until I noticed other repointed walls.
