Fairly big lumps of cement are detaching from below the ridge tiles. To put this right, would I be better to build it out from the bedding a bit at a time, allowing overnight drying in between, or simply do the whole cement fill at the same time? Would PVA help in this situation? The reason I ask is, I believe it's been repaired before and has, perhaps, been filled all in one go. The other issue may be the cement mix, it would help if I had some idea for the build out (if appropriate) and if the final pointing mix, if different? It would seem, for whatever reason, ridge tiles are usually bedded one day then pointed another day! Thanks.
Butter the joints is poor effort so always best to get the lot off and refit. To get straight the roofer I used got tung and groove timber and run ridge tiles along wood tung. Might be different to what you are asking about though. I'm not great at pointing so cheat and use duck tape to cover ridge tiles or brickwork as I point up as keeps them clean Roofer I know used 4-1 mix which is very strong but what he told me so I do the same on repairs. If ridge is set you can point same day. Not seen one done in 2 days Not my area... That's all I know..
As a matter of interest I have just had mine done and the guys came back the next day to put in mechanical fixings. They appear to be screws along the top between the tiles is this now a requirement?
Thanks for the replies. I presume the addition of mechanical fixing will be for health and safety should the tile ever be blown off.
Oh you can still bed ridges, but they should still be mechanically fixed as well, Marley ridges at one time had a wire imbedded to facilitate this but now they would rather sell you a dry ridge
Sorry to hijack thread but having the same issue as the OP - bits of mortar falling on to driveway. House is 16 years old and the whole roof was only repointed last year so not best pleased. Had a quote for dry system ridge tiles of 5k. Seems a bit pricey - house is a relatively modest 4 bed detached with hipped roof, about 70 ridge tiles in total. Are dry systems seen as an improvement on concrete/mortar systems?
