Hi, This is most likely a very simple question but for the life of me I cannot see how to repressurise my boiler. It is a Worcester Bosch Greenstar i erp and according to manual there are 3 ways to repressurise. Option 1 is a keyless method using a lever. My unit does not have this lever and looks like it is missing the entire unit connected to the cold water inlet Option 2 is to use a key, however, there's nowhere to use this key and the installer did not provide one attached to cover so I am assuming that this is not an option Option 3 is to use an external filling link, however, these hoses do not appear on my unit I have attached a photo of the underside of the boiler and the 3 suggested methods. To my untrained eye it looks like there is a piece missing that should be connected to the second right joint but I am not sure. If anyone has experience of this unit or can see from my photo how I do this I would be very grateful. Many thanks, Justin
hi you dont have either of the keyed filling methods, you will have a filling loop remote from your boiler, possibilities is there a unit below the boiler or any boxing, it can be away from the boiler on the next floor in a cupboard, check your benchmark boiler service book there it will have details of installer give them a call or if your in a new build ask a neighbour
Thanks Terry and Darren. I cannot see anywhere on the boiler itself where I can use the fill loop so I will try to find the remote loop. Appreciate your help
