Response wired alarm problem
Discussion in 'Support' started by Stephen Meeus, Jan 29, 2018.
My Response wired alarm system keeps giving a “tamper” alert when the system is not armed. What coul
  1. Informed user
    0 vote(s)
    0.0%
  2. Expert
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Stephen Meeus
    Stephen Meeus New Member
    My “Response” alarm system keeps going into a “tamper” alert when the system is disarmed. The backup battery has been replaced and is fully charged. What could be the problem. The system is about 8 years old.
  2. jonathanc
    jonathanc Screwfix Select
    tamper circuit open????
  3. Stephen Meeus
    Not as far as I’m aware.... how would I check that?
  4. spirits are real 2016
    spirits are real 2016 Screwfix Select
    you would need to go round and check each connection on everything that is connected to the alarm the alarm might sound when you take the panel off dont forget the alarm sounder box that would be my first choice because of vibrations from the road.
  5. Dr Bodgit
    Dr Bodgit Super Member
    Does your alarm panel have a log that shows you what the error is?
  6. KIAB
    KIAB Super Member
    Any battery in the external bell box?
  7. Stephen Meeus
  8. Stephen Meeus
    The main outside alarm is not going off: only a quiet alarm from the main panel. This problem only occurs very infrequently. It last happened 5 days ago and before then about 2 months previously. The main siren is in working order.
  9. Dr Bodgit
    But it could be the alarm battery not charging properly and getting end of life.
  10. Stephen Meeus
    It just says “tamper” on the keypad by the front door. I enter the code & reset and it returns to normal.
  11. Stephen Meeus
    I have just installed a brand new backup battery (external) are you referring to an internal battery inside the main panel?
  12. KIAB
    KIAB Super Member
  13. Stephen Meeus
  14. Stephen Meeus
    My alarm system is a PA6/PA8 6 zone system bought from Response Alarms via Screwfix.
  15. Rulland
    Rulland Screwfix Select
    SAB is actually a Self Activating Bell:rolleyes:
    Don't ya just hate pedantics? :p
    My moneys on bell tamper, wind, contraction/expansion with temperature changes, plus springs etc weaken over time-all of which can cause such an intermittent tamper.
  16. KIAB
    KIAB Super Member
    Thank you
    Just spotted that.:oops::oops:
    Was trying to hold a 3 way convesation, answer phone, & type at the same,we all make errors.:D
    Rulland likes this.
  17. Rulland
    I feel your pain mate, lol :cool:
  18. Stephen Meeus
    As I said, the main outside soren is NOT going off: It’s the other (quieter) alarm inside the main control panel that is being activated.
  19. Stephen Meeus
    I know that the main siren is working because I triggered the alarm intentionally. I also tested it by disconnecting all power-sources and it went off then too.
  20. Rulland
    The external sounder may not activate IF the alarm is not set and the panel sees a tamper:rolleyes: trust me.
    What's the point of it setting every audible device off if it thinks you are at home watching tv:cool:
    It's called 'internals only when unset on tamper activation' or similar terminology.
