Response wired alarm problem
My Response wired alarm system keeps giving a “tamper” alert when the system is not armed. What coul
  • Informed user
    Votes: 0 0.0%
  • Expert
    Votes: 0 0.0%
  • Total voters
    0
The external sounder may not activate IF the alarm is not set and the panel sees a tamper:rolleyes: trust me.
What's the point of it setting every audible device off if it thinks you are at home watching tv:cool:
Fair enough: what should I do then? I’m in the west-indies (where the alarm is installed) & will not return to the UK for 3 months. I doubt if I can source spare internal batteries here in Tobago. Could the fault be something unrelated to battery problems?
Link between T and A [SCB]
Leave the A wire in or both, but do not remove the A, that's supplying a -ve hold off to the bell.
The manual does actually show a factory fitted link in that position.
Thanks so much for your help! I’ll try that in the morning. Was the photo clear enough?
Back
Top
