Resting deck frame on loose stones
Discussion in 'Carpenters' Talk' started by bairdyboy1980, Feb 9, 2020.
  1. bairdyboy1980
    bairdyboy1980 Member
    Is it possible to lay my deck frame directly onto loose stones without digging out and cementing 4x4's in?
    9m x4m, my garden is all loose stones. I have tried digging out before for a clothes dryer and the stones are pretty deep.
  2. KIAB
    KIAB Super Member
    WillyEckerslike likes this.
  3. bairdyboy1980
  4. KIAB
    KIAB Super Member
    Probably around a 1mtr,maybe a bit more, all depends on size of joist being used.
    Something like this,dimiss the sloping site bit,spacing close to same on flat site.
    [​IMG]
  5. ginger tuffs
    ginger tuffs Screwfix Select
    how much do the deckpiers cost compared to nornal concrete block
    KIAB likes this.
  6. wiggy
    wiggy Screwfix Select
    Or stick it on slabs.
    bairdyboy1980 likes this.
  7. KIAB
    KIAB Super Member
    Concrete block would do same,& cheaper, need a bit of dpc on block to stop damp rising.
    bairdyboy1980 and ginger tuffs like this.
  8. ginger tuffs
    surly damp would be needed on piers aswell and dont forget to allow air to circulated
  9. bairdyboy1980
    would this be the same spacing for composite (still timber joists)?
  10. dwlondon
    dwlondon Active Member
    The loose stony base sounds firm enough to build a deck on. I'd clear a place of loose materials. Then just lay slabs on a pat of mortar or concrete, where you need them and make those where your posts sit.
    Many decks seem to be over built for what they are. Much of what you need to make the deck stable and strong can be achieved with the carpentry work.
