Resting joists on ledger board - decking
Discussion in 'Carpenters' Talk' started by SrD123, Mar 31, 2021.
  1. SrD123
    SrD123 Member
    Hi,
    I'm trying to work out the best way to build the subframe of my decking. Becuase of the pebble dash on my house sitting 30mm proud of the brick I can't attach the ledger board where I would prefer but if I was to drop the ledger board down 140mm and sit my joists on top with a notch taken out to go around the render then it would work.
    I'm just wondering if this would be acceptable? if it is would it be ok to just put a coach screw at an angle for each side of the joist into the ledger board to hold it in place?
    I can't seem to find anywere locally that sells hurricane ties.
