Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
a house that has galvanised conduit throughout
There are literally hundreds of thousands, if not more, houses and flats up and down the country tubed in solid conduit. Any decent spark will know how to rewire them.I've only ever seen one other house like that,
when you've finished arguing among yourselves can anyone point me towards someone who does have the necessary skills for the job?
PS modern switch plates and socket plates and light fittings are already done - fitted perfectly on the original conduit back boxes, which are way better quality than the flimsy modern ones, IMHO.
Barrel pipe which comes in 3 grades, red, yellow or blue has never been used for electrical work. It is used for gas, water and steam pipes and also air lines, not as an electrical conduit.threaded half inch barrel
Sorry I can't help to recommend a spark in Brighton as not from that area.can anyone point me towards someone who does have the necessary skills for the job?
You are obviously not an electrician or you would know this. There are a few different ways to tube out and wire a house or flat in conduit.
Barrel pipe was never used for Electrical work. Conduit was used and still is used for Electrical work. It is really quite obvious you are not, or ever have been an Electrician.When rewiring posh buildings in London, they would quite often use threaded half inch barrel,
