Ronseal Smooth Finish Filler
Discussion in 'Painters' Talk' started by Joseph Brown, Jun 12, 2018.
  1. Joseph Brown
    Joseph Brown New Member
    Morning All,
    DIY ask here. I’ve cocked up by not wiping up enough Ronseal smooth finish filler excess away. I’ve a light sanding block but it doesn’t seem to make a dent. Any ideas? This is being painted but I feel it’ll be obvious as it’s probably 0.1mm thick.
    Thanks.
  2. DIYDave.
    DIYDave. Well-Known Member
    No experience myself with this filler but guess it’s a regular powdered - ready mixed filler ?
    Shouldn’t present a problem to sand totally flat, perhaps ur using too fine a grade sanding block ?
    If you’ve gone way to heavy with the filler (which you haven’t), can use P60 paper just lightly for fast excess filler removal
    Then move up to P120 to get nice and flat, final rub over with P180 to finish off and remove any scratches in filler from paper
    Always good to use a block of wood with paper wrapped around or a ready made hand sander
    Your 100% right to be concerned though that if not perfectly blended in, the filler will show through the paint. Matt emuslion does ‘help’ to slightly disguise imperfections but any paint has a funny habit of magnifying flaws
    Better to get filler totally blended into surrounding wall surface before painting. Should sand quickly with P120, never used the Ronseal but can’t see why not
    Mist coat filler patches before painting over so as to get an even finish to the emulsion - good luck
  3. Astramax
    Astramax Well-Known Member
    The biggest trouble with the ready mixed fillers is that they do dry out to be exceptionally hard, sand it flat using 120 grit and a sanding block.
  4. Joseph Brown
    Thanks for the advice Gents. Yeah I’ve done my best by hand and I can’t get it smooth out flat.
    Would an electrical sander work?
  5. Astramax
    Have you got a random orbital sander? a palm or delta sander will get it flat.
  6. Joseph Brown
    Not at the moment, I was looking into them and/or a rotary tool. Thoughts?
    It appears I’m not the only one to see how stubborn this stuff is, so far from ideal for my use case.
  7. Astramax
    Chip it off and re fill using Tou Pret interior filler, a far superior product.
  8. DIYDave.
    As I said earlier, I’ve never used this filler but can’t understand why it can’t be sanded flat. You mentioned a sanding block in ur opening post but, no mention of grade
    I use the Ronseal 2 part wood filler loads and that sets like stone - yet sands easily with P120
    Can’t understand how this wall filler is harder than the 2 part stuff
    You’ve got a heavy looking ‘orange peel’ effect going on with your paint (realise photo is zoomed in)
    Did you try to sand before painting wall as looks like uv painted over filler
    Out of interest, what paint are you using ?
  9. Joseph Brown
  10. DIYDave.
    Is it just this 1 patch as per photo that you have trouble with ?
    If it really is impervious to sanding (although can’t understand how and why), by using an electric sander your likely to sand the surrounding wall surface and not the ‘lump’
    Are you still using the sanding blocks - like the foam things ?
    Any regular sandpaper to hand ? P120 for instance, give it a try
  11. Astramax
    The orange peel effect could be a Polly Ripple/Artex type product, needs steaming off.
  12. Joseph Brown
    Yes I’ve tried 120 and a 220, no luck. Yeah that’s also my concern, I could do more harm than good (as I have with this product). That said I can’t leave it... any ideas?
  13. Joseph Brown
    The product is Ronseal Smooth Finish. It just seems impossible to sand by hand. I’ve used three types of sandpaper now. Thoughts?
  14. DIYDave.
    I’m guessing more than likely poor roller technique (don’t mean to be rude OP)
    Overloading roller
    Heavy pile roller
    Repeatedly rollering over same area
    Paint too thick
    Hot weather, paint drying quickly
    Etc
  15. DIYDave.
    Where’s kools when we need him ?
    He will have the perfect suggestion to this problem :)
    But as an alternative, as Astra said, just knock out this patch and buy another filler - Toupret/pollyfiller/etc
  16. Joseph Brown
    Best tool to knock it out with?
  17. Joseph Brown
    No offence taken. Whilst the roller technique will be amateur, it’s definitely the contrast behind a protruding smooth surface (Ronseal) vs. The underlying paint. The specky affect was already there from the underlying paint job.
  18. Joseph Brown
    I assume there’s no way to PM/IM him? Really keen to put this to bed tomorrow.
  19. WillyEckerslike
    It was a joke. Kool's stock answer to most problems was 'Dynamite!' You are getting good advice from the respondents already.
