Roof joists - Advice please
Discussion in 'Builders' Talk' started by Darrell Webster, Mar 14, 2019.
  1. Darrell Webster
    Darrell Webster New Member
    HI All,
    Im currently looking into using the space above the garage but the joists are way to small to accept any loading. There are 5 joists @ 600mm centres spanning 5215mm and they are 72mm x 34mm thick, without taking them out which would mean dismantling the garage ceiling what options do i have for strenghening these? any advice appreciated.
    Thanks
  2. gas monkey
    gas monkey Active Member
    put the new joists along side the old rest on wall plate bolt to existing rafters
    AlvyChippy likes this.
  3. AlvyChippy
    AlvyChippy Active Member
    Had similar job while ago and it is remembered as hellish one.
    I had to fit slate tiles, instead of felt and preserve water tight ceiling underneath, 6", instead of existing 4" and double up (instead of ~600), had to fit them in between. Length was only just allowing to swing them in to the right length cuts to fit between ridge board and wall plate, but needing "bowing" to be upward had been using levers and club hammers to fit them in. Basically needed to chuck them in in pairs and reposition after wards.
    Depending if you get inspected and many other variables as for "residential dwelling" strength, I'd recommend 4"X2" and doubling the amount to reduce almost absolete these days spacing of 600.
  4. gas monkey
    what loads are we refering to
  5. AlvyChippy
    Garage (shed) converted in to domicile structure has different load- strength requirements
    IE old coal storage outer building reasonable roof had to go, converting in to the kitchen and has been inspected no lesser than 3 times by local inspector, including requirement for RSJ beam etc, however appearance from outside hadn't changed at all.
  6. gas monkey
    well done not looking for a row just noisy and ment what loads was mr webster going to use
  7. AlvyChippy
    Just to clarify, I used different jobs as examples.
    As for loads - need to have calculations done, in accordance to the change of structure designation... Although I have a feeling it is one of the "diy conversions" so having roof the same, ceiling the same strengthening threefold should be sufficient
  8. Darrell Webster
    The current rafters run length ways 17 1/2 ft long (from garage door to back wall) which seems weird, im planning on putting about 300-400 kilos of stuff up there spread out of the 17ft x 8 ft space. im asking for advice as it seems odd the way ceiling rafters are because i presumed normally they would run accross the shortest span?
  9. Darrell Webster
    Thanks, its just gonna be for storage above the existing garage nothing else, its the length of the current rafters that's puzzling me @ 17 1/2 long they seem to be in the wrong way round surely they should have spanned the 8 ft width?
  10. gas monkey
    pic be handy yes does seem odd
    if spread poss be ok you,ll be the first to know
    put a pic on may be able to shed more light cheers
  11. AlvyChippy
    Indeed as discussion so far is in "swings and roundabouts"
  12. Darrell Webster
    Hes a pic looking to the garage door, its exactly the same behind me.
  13. AlvyChippy
  14. gas monkey
  15. Darrell Webster
