Roof on structure
Discussion in 'Builders' Talk' started by Ajaz, Jun 8, 2020.
  1. Ajaz
    Ajaz New Member
    Hello. Let me start by saying my builder ghosted on me after taking money... Right ok, I have 3m x 3m shed that's being built. The blockwork is up and now needs timber roof structure and tiling. I would greatly appreciate some advice on what timber I need and how to go about making it.. I know I need joist hangers but that's about it. Just about a DIYer as you can clearly tell. thanks for your help
  2. Severntrent
    Severntrent Screwfix Select
    Might no need joist hangers, depends on roof type, picture and what is your proposed roof construction/layout
  3. Jord86
    Jord86 Screwfix Select
    Not all builders are cut from the same cloth, don't let it sour you. What style of roof are you going for? Where in the country are you?
  4. Ajaz
    Ajaz New Member
    It is a pitch roof with. It is a shed attached to current building. I will send picture In next post. Just need to take fresh pictures. Thank you for your reply.
  5. Ajaz
    Ajaz New Member
    h
    Thanks jord86. But I've been left in a mess. I'm in Nottingham. Thanks
  6. Ajaz
    Ajaz New Member
    Tiled pitch roof. Thanks
  7. Jord86
    Hours away I'm afraid.
    A double pitched roof where it slopes down each side and runs into your main house ie a gable end roof, or a single pitch roof where it slopes away from your main house wall ie a lean to roof?
  8. Ajaz
    Ajaz New Member
    No idea why but It won't let me upload the images. Thanks
  9. Jord86
    2mb or less apparently.
    Ajaz likes this.
  10. Ajaz
    Ajaz New Member
    Yes double pitch. Thanks
  11. Ajaz
    Ajaz New Member
    It didn't let me still. No idea
  12. Jord86
    Post your photos when you can and we'll take it from there.
  13. Ajaz
    Ajaz New Member
  14. Ajaz
    Ajaz New Member
    Pictures are up. Thank you for your replies
  15. Jord86
    That's going to be a monopitch roof not a gable, presumably there was an old outbuilding there which you demolished and rebuilt, looking at the lead soakers in your house wall?
  16. Ajaz
    Ajaz New Member
    Yes there was an outbuilding which we demolished. I'm not very technically minded so please forgive me if I repeat questions. On the outside wall the blockwork needs to be cut according to the pitch
  17. Abrickie
    Abrickie Screwfix Select
    Just out of curiosity was the original outbuilding demolished recently ? :)
  18. Ajaz
    Ajaz New Member
    Hi abrickie, no it's been a while to be fair. Cheers
  19. jonathanc
    jonathanc Screwfix Select
    Ok few observations. The roof slopes down from the high wall to the wall with door in? If so the wooden lintel doesn’t look good enough. I’d prefer concrete lintel
    second do you have tiles/slate? That looks shallow pitch so you’ll need to watch the headlap.
    Without sizes cannot really advise on joist size I’m afraid.
    just a thought: you might want to consider tile effect sheet steel. Very lightweight and easier to make watertight on shallow putch
  20. Ajaz
    Ajaz New Member
    Hello Johnathon. Yes the roof slopes from high wall to the where the door is.. I asked for pitch roof with tiles. The builder bought 600x300 man made slate tiles.. The slope was a lot less and I had to do a couple of courses at the back myself after he ghosted... The dimensions are 2.8m x 2.8m.. From back wall (starting point of slope/top end) to the lower part (door end) it measures 3.2m... If you could share a little information on the tile effect sheet. I'll consider it too. Thanks
