Roofing felt above eaves/starter course?
Discussion in 'Builders' Talk' started by Mills, Oct 12, 2018.
  1. Mills
    Mills New Member
    Hi all,
    Looked at a stone slate roofed property recently and the felt has been sandwiched between the eaves/starter course and the first course of slates. I have come across this on a few other properties, again stone slate roofs.
    Is there any legitimate reason for doing this or is it incorrect? Surely any moisture that runs down the felt would end up trapped behind the top edge of the eaves slates?
    Thanks
  2. Jord86
    Jord86 Well-Known Member
    It's correct. Any moisture that runs down the felt ends up in the gutter, as your photo shows.
  3. Mills
    Mills New Member
    It's not normal practice though, so why do it?
    Thanks
