Roofing straps
Discussion in 'Builders' Talk' started by Justiniw, Aug 9, 2021.
  1. Justiniw
    Justiniw New Member
    Hi, I am selling a 1960’s house, the surveyor has stated it is not strapped down and needs to be remedied. Assuming this was constructed to regs at the time? Can they force retro fit? Thanks
  2. jonathanc
    jonathanc Screwfix Select
    Absolutely no. The surveyor is acting for the buyer??? If so they are just fault finding to try to knock the price down.
    I suggest you respond by saying that the building was built in the 1960a and met the required standards of the time. There has been no issue with the roof over the last 60 years(I presume this is the case?). If the buyer wants a building constructed to current standards then they should look at new builds abs not 1960s properties.
    if you get any further push back on this position then re market the property.
    FlyByNight and Justiniw like this.
  3. Justiniw
    Justiniw New Member
  4. Justiniw
    Justiniw New Member
    Thanks that’s what I thought, cheers
  5. jonathanc
    no problem glad to help.
    Justiniw likes this.
  6. stevie22
    stevie22 Screwfix Select
    1987 gave it a pretty fair test.
  7. Justiniw
    Justiniw New Member
  8. Justiniw
    Justiniw New Member
    Yes true
