Room Thermostat Wiring
Discussion in 'Electricians' Talk' started by TinkerCharlie, Jul 31, 2017.
  1. TinkerCharlie
    TinkerCharlie New Member
    Morning folks,
    Need wiring advice changing over a very old room thermostat to a Honeywell DT90E model.
    Here's some pics of the current set-up:
    [​IMG]
    [​IMG]
    New Honeywell Room Thermostat back-plate:
    [​IMG]
    Can someone guide me as to where the existing wires go into the new back-plate please? Current to wires will be off!
    Cheers,
    Charlie.
  2. dobbie
    dobbie Well-Known Member
    Someone has joined the live and switched live in that stat therefore it would not have worked.
    The blue in the old stat is a neutral,put it in a piece of connector strip to make safe as it is not required.
    The red which should be live goes to A in the new stat.
    The yellow which should be the switched live goes to B,also put a piece of red tape on this to show it is a live cable.
    TinkerCharlie likes this.
  3. TinkerCharlie
    You're a star Dobbie, thanks. I didn't think it looked quite right.
    Does the yellow/green wire still need to be earthed?
  4. dobbie
    Put a piece of connector strip on it the same as the neutral to make safe.
  5. TinkerCharlie
    Great stuff. Many thanks for advice.
  6. TinkerCharlie
    Quick question: if a room thermostat has batteries, will it only work with them in, as when I took them out the display went dead.
    Leads me to think that perhaps there is no AC current to the unit if so.
  7. TinkerCharlie
    Scrap that. Should have tested it first with the heating on. Seems to work fine...
  8. Devil's Advocate
    Devil's Advocate Well-Known Member
    As you've sussed out, it'll only work with batteries in - it does NOT use the power that's in the cables.
  9. TinkerCharlie
    Cheers Devil's. Interesting it only uses the battery power. Learnt another new thing!
  10. Devil's Advocate
    All the room stat does when it decides the boiler needs to come on is to close a switch inside it - and that joins the two wires you have there, the red and the yellow.
    As Dobbie says, tho', your old stat was seemingly wired incorrectly. The Red should be the 'live' and the Yellow should be the 'switched live', so the fact they'd been wired together suggest that the stat wasn't doing anything as it was always sending a 'switch on' signal to the boiler.
    So I'm guessing you controlled the boiler and CH by using the separate timer control? And basically as along as the timer was timed to be 'on', the boiler was firing - regardless of the temp of the room.
    (Psssst, anyone considering fitting a better room stat like the DT90E should also be seriously considering fitting a programmable stat instead. This will do both jobs - timings and temps - in a much more useful fashion.)
  11. TinkerCharlie
    Oh I have a programmable one upstairs. Just moved in to the place so discovering new and interesting electrical adventures!!
    Devil's Advocate likes this.
  12. MGW
    MGW Active Member
    The neutral in old stat goes to a heater to reduce the hysteresis, but with the electronic type it needs around a 0.5 C hysteresis or the boiler would be switching on/off every 5 minutes, with a condensate boiler where the flame height is variable the thermostatic radiator valve can reduce the hysteresis so it can hardly be detected, specially using eTRV heads, which is why on modern boilers the wall thermostat is only there to switch off the boiler to reduce cycling.
    With old boilers however the wall thermostat is still king, and the TRV is only to stop in the main bedrooms from getting too hot. So with an old boiler the programmable thermostat is very good, but with new boiler in most cases pointless, it is either super simple, or go all the way with something like EvoHome.
  13. Colin Key
    Colin Key New Member
    I am also changing to new DT90E. I need advice on wiring. I have red, blue and yellow/green wires from the old thermostat. I understand this a 2 wire system though. Can somebody advise which ones are required please. Many thanks.
  14. Devil's Advocate
    Hi Colin.
    Post your info an here too so's we can all have a gander.
    Is the old 'stat still in place? If so, take photos of where these wires go to.
    If not, did you note - or can you remember - which terminal they went to on the old 'stat?
    If you look now at your old 'stat, can you say for certain "The red wire went here, the black one went..."
    REALLY importantly, where did the green/yellow (earth) wire go to on the old stat?
  15. Colin Key
    Re-wired now. Found out old cable had earth as the switched live!
  16. Devil's Advocate
    Jeepers!
    Well sorted.
    (Er, did you do it properly? RED = LIVE, BLUE? = SWITCHED LIVE (with a ring of red tape around it) and YELLOW/GREEN = EARTH, safely terminated behind the 'stat. Ie - did you adjust the wiring at BOTH ends?)
  17. dobbie
    It sounds like he had a 3 core cable,Red,yellow and blue with the yellow as switch wire which would be correct.
  18. Devil's Advocate
    Which is why trying to help some folk on here with only written descriptions can be a 'mare...
  19. TinkerCharlie
    Now that I've done mine, annoyingly I want to upgrade and be able to programme the heating downstairs instead of up. Should have taken your advice in the first place Devil's!:
    So I want to be able to do said, not spend too much money. Is it just a case of switching out the DT90E and replacing with a programmable thermostat? Will the programmable thermostat override the programmable boiler controls upstairs located near the boiler in airing cupboard, or is it not as straightforward as that?
    Was looking at this on Amazon: https://www.amazon.co.uk/gp/product/B074W7CBJN/ref=ask_ql_qh_dp_hza (just realised posted from Hong Kong!!)
    ...or would I need something else?
    Thanks
    Charlie
  20. Devil's Advocate
    Hi Colin.
    That one looks great, but could be a bit of a gamble. It's mainly designed for underfloor heating, tho' I understand it does also have a built-in thermistor to sense room temp - which is what you want.
    You'd need to confirm this.
    Also, how it's wired is slightly different - it doesn't have a pair of switching contacts like most (a COM and a NO), but instead fires out a L and N to serve the heating load.
    I suspect it'll work ok if you connect L and N as you would normally to L and N - the two inner terminals of the 4 - and then connect just your Switched Live (is it yellow?) to the L1 - the furthest left terminal.
    That's all theory.
    You can get a 'known' IQE from our hosts for £20 - and you know that'll work.
