I have never seen these sorts of lights before. Feeling a bit stuck, & indecisive. To light a 6m x 5m "workshop" (general stores and tinkering) area. https://www.aliexpress.com/item/100...c4-0&pdp_ext_f={"sku_id":"12000023369764675"} Black 18w, it says "lighting area 8-15 sq m". I was thinking of buying 6. Do you think that they're any good, or is 6 too many (they needn't all be on at the same time).
Yes, quite common now although not seen them used in a workshop. https://www.tlc-direct.co.uk/Main_Index/Lighting_Menu_Index/Circular_LED_Panel/index.html https://www.tlc-direct.co.uk/Main_I...ad_Internal_Index/LEDlite_Galaxy_2/index.html Are you trying to avoid LED battens for aethestic reasons?
Thank you very much for your reply. I claim ignorance, lack of headroom, and aesthetics. Any recommendations about lumens for the area (more ignorance)?
It looks from "omnicalculator, lighting requirements" that I need somewhere between 3,000 lm and 12,500 lm, depending on whether it's agarage/workshop, living area or kitchen. Fantastic. So I need (assuming 1750lm) between 2 and 7 lights of that size. I feel really thirsty now.
