routing curves on worktops
Discussion in 'Kitchen Fitters' Talk' started by Well Done Award, Oct 15, 2018.
Tags:
  1. Well Done Award
    Well Done Award New Member
    Can someone settle an argument please? I say you cannot route a curved edge on a worktop that has a rounded front edge - my mate says you can. also can someone recommend a jig for cutting curves?
  2. chippie244
    chippie244 Well-Known Member
    You can, most worktop jigs.
  3. PhilSo
    PhilSo Active Member
    Brevity is your passion Chippie.
    I'd be interested also.
    Presumably you have to have a router bit to match the curve/rounded/profiled edge of the worktop.
    PhilSo
    longboat likes this.
  4. chippie244
    No, precision and skill.
    blarblarblarblar and wiggy like this.
  5. PhilSo
    Can you share your skills please
    PhilSo
  6. chippie244
    You should have a rounded corner on your jig, set it up so your cutter goes into the worktop by the thickness of the laminate and flush on the other edge, cut your edging trim to exactly the right length and Bob's your uncle and Fanny's a daft name.
  7. longboat
    longboat Well-Known Member
    You can certainly bring a curved edge onto the pre-formed edge of a worktop. Most worktop jigs have edges at different radiuses for that exact purpose.
    I'm a bit uncertain of the question, though.
    Do you mean you can't curve the edge and also route in the profile of the the round over?
    If that's the case then in theory it is possible with the correct cutter, but I doubt you'd find an edging strip to accommodate.
  8. Mblack
    Mblack Member
    It’s same answer as to when asked can you put laminate work tops on a Belfast sink... you can but it’s a bodge, a curve with laminate requires square edge work tops.
  9. PhilSo
    Is it a solid wood worktop or laminated?
  10. chippie244
    I was presuming routing the curve on a breakfast bar front.
  11. kitfit1
    kitfit1 Well-Known Member
    Yes you can put a curve on laminate postformed tops, it has to be a very shallow curve though. A full curve into a postformed edge looks absolutely horrid though, just a large area of black where you have to file the edging to meet the postform.
    CGN likes this.
  12. CGN
    CGN Well-Known Member
    As above. See it all the time...looks *****.
    kitfit1 likes this.
  13. longboat
    Well done award to PhilSo.
    PhilSo likes this.
  14. PhilSo
    Thanks
  15. CGN
    Yep, if solid wood then no probs.
  16. chippie244
    It does depend on the colour of the worktop with laminate.
  17. PhilSo
    My preference.
    Single Spanish
    PhilSo
  18. chippie244
    My preference, single malt.
  19. PhilSo
    Are you buying .
    :D
  20. chippie244
    It depends on if I get the curve job :)
