Routing instrumescent strip in existing frame for fire doors
Discussion in 'Carpenters' Talk' started by Jitender, May 16, 2018 at 6:51 PM.
  1. Jitender
    Jitender Well-Known Member
    As part of the loft conversion, i have to upgrade 2x doors downstairs to fire doors.
    Don't want to put the strip in the door as feel it would ruin the.
    I have a Katsu router which would be perfect to do it but the fence supplied wont go in an further, plus it too big height-wise as will hit the architraves.
    Sample of what I want to achieve. these linings were machine for me at the timber merchants.
    Katsu router with guide.
    Base of router with guide.
    Door linings I want to route out for the strip.
    Will be removing the door stops.
    Other than making a jig is there any other way to do this. I know the router wont reach upto the corners an the bottom of the frames, so will need to finish this by hand.
    Router has 4 screws which secures the plastic base to the bod of router, thinking I could make something with ply using these fixing points?
  2. WillyEckerslike
    Sorry if I'm being thick (highly likely) but won't the fence reach if you use the other hole?
  3. CGN
    CGN Well-Known Member
    Easiest to do door with one of these.
    https://www.axminster.co.uk/axcaliber-intumescent-strip-cutters-ax834745
  4. Jitender
    Think it might work, never used the fence and accessories for the router. The only thing it will hit the architraves, as they are set in 6-8mm from the edge of the linings.
  5. CGN
    I've done them before on my HMO's with my 1/2" router. I cut some MDF to use as a fence and popped a few screws through into the frame and used a guide bush in the router.
  6. Jitender
    I can see that the bit you've linked to has a top bearing fitted, so will need a temporay guide fixed into the frame.
    I do have a large 1/4 router which is more accurate, but will be difficuklt holding vertical and upside down. The katsu is much lighter, but depth setting is a little crude.
  7. CGN
    Its designed to go around a door. So easy to use.
    If your door linings are perfect, then you may get away with using a fence along the frame. If not, a temporary fence is the way to go.
  8. Jitender
    Looking to make a jig. Can use the base once unscrewed for the 4xfixing points.
    2x stops fixed to accommodate different thickness of linings.
  9. Jitender
    Yes can see now as cutters on the side so follows around a door.
  10. Jitender
    Going to be tomorrows project.:)
  11. Jitender
    Ok
    I've built the jig and seems to work. Ordered a 15mm wide router bit
    Will upload pictures tonight.
  12. CGN
    Practice on scrap first. You only need a bit of unevenness or 'chatter' and you'll end up with a wonky slot. :confused:
    Jitender likes this.
  13. Jitender
    this is it.
    Only took me a small amount of time to make this using offcuts. Fixed a strip of wood on the top to act as a handle.
    Underneath. Router has had plastic base removed and screws replaced. Need 2x longer screws to order. The pine strip wood acts as the fence.
    Made the mistake of having the cord outlet positioned to the top :oops:, would have been better to the side.
    CGN likes this.
  14. GoodwithWood
    GoodwithWood Active Member
    For me if it's a reto fit then either the door gets a rebate for the intumescent strip or the lining comes out and gets replaced.
    Are you sure the lining is suitable for a fire door application? It should be at least 30mm thick and not made from materials such as Ash (no pun intended).
