I have just had a builder install some padstones and RSJs for some new openings in a cavity wall. I am concerned about the installation for a few reasons. 1. He has installed the padstones (220 x 200 x 100) sideways so that they span the cavity. I guess this is good for load spreading, but I am concerned as I am unsure whether they are supposed to be used side on, they are bridging the cavity and their now 'top' don't seem to be a smooth as their side faces. This means that the RSJ is in point contact with the high points of the padstone (not evenly spread load). 2. The padstones are off level. I'm sure this can't be right. I guess it could be dry packed between the padstone and lintel, but seems like a bodge. 3. The mortar under the padstones has been packed with broken brick. I'm not sure if this is a problem, but would really appreciate some expert advice as he is sending through an invoice this evening.
You don't usually lay a padstone flat to bridge a cavity wall, padstone sits on edge on one course of brickwork, you then build the second row with brick or block work.
Hi mate, if that photo is representing what your builder has installed then it's very poor to say the least. Do you have any other pictures showing the whole scenario please? Can't understand why the padstones are so low if the guy is a builder who does this type of work day in and out. You can pack the rsj off the pads with slate to level it if needed as it is a durable material, but certainly nowhere near the depth needed for what the photo shows. The padstones should be placed on top of and in line with the supporting walls, not bridging the cavity, with the rsj bearing fully on the area of the padstone. At best would like to think it was only a temporary installation, but as he has cemented it in I would seriously question him if he was planning to leave it like that.
OP hasn't posted any photo's yet. When I've installed rsj's ,have had to use steel shims instead of slate to keep BC happy.
I'm just looking at my details. SE has recommended leaving any props in for at least 7 days. On the external wall, how is the outer skin being supported? If the steels work hasn't been plastered over, would get BC to come over and check, they told me that they wanted to see any structural work before plastering over.
Even using a strong mix, you need a week before removing props, well you did in the old days. Last year, I seen padstones installed, & brickwork below padstone was commons, & not a engineering brick in sight, years ago you always built up with engineering bricks, how times have changed. I bet builder probably didn't even involve BC.
Ah I see, jumped the gun a bit there sorry! Not that I don't agree with a bit of overkill here and there for peace of mind but does pertube me how one building control officer will require very different methods and measures used compared to the next(not just meaning rsj's now mind), particularly if it's in the same postcode area. No point arguing with them though......
This is taken from my calcs: Install steel beams and shim / dry pack beams as necessary onto padstones to ensure full load transfer. d) To minimize cracking of the walls above, preload the new beams by using machined steel folding wedges rammed home. If the beam is not preloaded there is a risk of initial cracking to the walls above as the load is transferred but this will not be progressive. e) After preloading the beams dry pack the gap between existing wall and the beam using a minimum thickness of 30mm of sand and cement 3:1 mixed to just bind and then rammed home to ensure a fully packed joint for the full width of the beam/wall. f) Leave props in place for at least 7 days until the packing is cured.
sorry, trying to upload photos, but failing due to file size restrictions. First time I have used this site.
Total carp,very poor standard of work,completely unacceptable, get BC in to inspect. Lintel isn't sitting properly on padstone. I'm not there, but looking at photos, I think I would have taken the lot down & built a proper solid pier.
Sorry CRL but from those pics, that's a poor job. KIAB is right get the BC in then you have extra weight to throw at your "cough" " builder" to get a proper job done, or at the very least rectified. Strongest point in all the pics is the Acro prop. which in fairness, looks like it's in the centre of the beam.
