Hi chaps, I wonder if any of you chaps can help. My customer has a Salamnder pump which works fine for his shower etc but somebody has connected an outsde tap to the cold outlet of the pump. This means that when he waters his garde (which takes about an hour) the pump is running constantly on cold only which the pump is not designed to do. It will be difficult to connect the outside tap to the rising main but is there a pump available that will do hot and cold together but also hot or cold individually? Thanks
