SANINDUSA NAU ( cistern) help
Discussion in 'Plumbers' Talk' started by gazza2, Jun 25, 2007.
  1. gazza2
    gazza2 New Member
    HI
    DOes anyone know how to get the top off the cistern on a sanindusa nau toilet ?, its got two pushbuttons on top, and no visible means of fixing, it will not move when i try to lift it
    I need to adjust it as its continually running down into the pan ( the water that is )
    Thanks
  2. Noddin
    Noddin New Member
    Hi I'm not sure if its the same make as i have done before, but try and turn the outer chrome ring around the two buttons anti clockwise.
  3. tomplum
    tomplum Active Member
    sometimes the cover with the 2 buttons will flick out to reviel a screw, undo and hey presto
  4. thollick
    thollick New Member
    Hi had the same problem, wife got it undone! It unscrews. Took the whole thing to bits and it still don't work. Anyone know where to get parts?
  5. HOTDOG ø
    HOTDOG ø Active Member
  6. plumber carl
    plumber carl New Member
    or phone the manufacture thay nearly all send the part FOC OR £60 COMPLEAT new wc with guarantee
  7. Bit Of Advice
    Bit Of Advice New Member
    Or go to your merchants and buy a universal if it will fit , be cheaper than £60.
  8. doing a bit
    doing a bit New Member
    change it for a torbeck flush valve, screwfix sell em, as the buttons are on a cable the cistern height is no problem
